shahmirous
Hi to everyone,
I am trying to control a Micromaster 440 by a S7-300 PLC.
I read some documentation about the Micomasters and tried to setup my hardware in a PPO1 mode.
When I was inserting object to set the mode (PPO1) there were two menus comming up SIMOVERT and DP V0 SLAVE which both have PPO1 in their sub popup menus??? can some body tell me what is the difference?
When I finished my hardware configuration it appeared with two slots??? 4AX and 2AX which have different addresses in them , what are these addresses? which one is PKW and which one is PZD???? this is how it looks :
slot 1:
4AX PPO1:4KW 2PZD inputs:657...664 outputs:553...560
Slot 2:
2AX PPO1:4KW 2PZD inputs:653...656 outputs:549...552
And Finally can just somebody tell me which one of the above addresses are control words and status words and how I can send and recieve these to and from the VSD?is there any documentation that helps?or a simple sample program with description?
thanks alot
Shahmir
slot 1:
Slot 2:
thanks alot
Shahmir
