Micromaster 420 Serial PC Connection Problem
Jarryd
Apr 2019
belgium
:oops:
Hello,
today tryed houres to connecting the micromaster 420 of my kaeser compressor to my laptop with the connection kit (MM4 Connection Kit) i bought of siemens.
first tryed with my laptop :
-installed V5.3 starter software
-setup com port usb to serial to "com1"
-setup in starter software “PC COM-Port (USS) to com 1 / baud 9600/...
cannot connect
*second attempt:
-installed on old laptop with serial port.... doesnt support xp
*third attempt (because i was thinking the serial to usb adaptor was the issue...)
-used desktop with serial port and win10
-installed V5.1 starter software
-setup serial port in windows to com1 /BR 9600/...
-Setup in starter software “PC COM-Port (USS) to com 1 / baud 9600/...
Nothing again no connection....
so after tried these steps above over and over i dont know what it can be if i use the com directly and setting like in manual...
settings in MM420 is did is
P700 =4
P2010.0= 6
P2010.1=6
p2011.0=0
p2011.1=0
P2012.0=2
p2012.1=2
P2013.0=127
p2013.1=127
Is there anything i forget to do for this setup?
please any advice what this can be?
thanks a lot
Hello Everybody, Recently we changed the gearbox which has different ratio than the original one on a motor which is controlled by Micromaster...
1,899
Hello All People, I am useing S7 300 plc and Micromaster 420 with Profibus(CB). the problem is that when i set frequency setpoint in plc through...
1,690
Hi, I want to know how a simple micromaster 420 VFD without Communication board and other profibus modules,only attach profibus cable at its...
1,647
I am experiencing an issue with the profibus modules on micromaster 420 drives. I would bet others are having the same problem so hopefully...
4,051
I've been trying to find the max voltage rating of the 24VDC digital inputs on the Micromaster 420/440 drives from Siemens. I have found the...
3,264
