akyilmaz1977
hi everybody
i have mm440 and have a strange problem.this mm440 connect to oscilation AC motor.when the motor is running , only i see only 8hz and 0,24A current(current is constant).threshold temperature values 130C,no ptc or kty84, temperature value coming from I(square)*t calculation.even though current is constant how the temp. increase?
where is the "t" come from? is there any parameter or what?
best regards...(for no alarm i increase P0610 to 180C,if i can not take any solution , i will cancel fault trip for F0011)
