Siemens inverter g110 f0011 motor overheating fault
ford
Mar 2003
26
Hi I have an f0011 fault I had a jam in the motor then the fault appeared how can this be cleared through the key pad . It will not clear with a power down power up. I do not see a thermal sensor detecting the temp of the motor could the settings be wrong
Thanks !
Try pushing the "FN" button on the keypad and see if this will acknowledge the fault.
If this does not work, try turning off the drive, disconnecting the load side wiring to the motor, power the drive back up, then press "FN" and see if the fault will clear.
This should work but if not you may have to change the drive
I seem to remember this same thing happening once to me on a MM440 and the fault would not clear even though the motor checked out fine.
If the fault does clear but returns, then the motor may have problems.
BCS
you can try Factory Reset (P0970=1).First set P0010=30(factory settings). But then you must set all parameters .-)
Hi , A little off topic , hope you don't mind I have a Siemens Sinamics V20 Inverter On a 0 - 10 v analogue input as a speed reference...
1,082
It has been long that I am working in PLCs' field. I have a 2021 question now. How do you commission a line remotely? Firstly I said no way but...
2,219
Hi all, I've hit a bit of a brick wall and need some help. I'm currently trying to get a Siemens S7-1200 PLC to talk to an Eaton DE1 Drive I'm...
3,687
dear all siemens simovert expert i have a machine in wich siemens simovert inverter 22kw is installed in wich first 'E' error was come we worked...
1,893
Dear all, I need some guidance when coming to define the Siemens hardware architecture of a three stage lift automation solution. I have only...
5,804
