Microwin S7 200 comments
sonarbell
Mar 2004
Leicester
28
Hi All
Is it possible to shift the network comments by a specified amount like you can in Logix 500 ??I think its called offset or something like that...
My brain hurts from trying to remember a problem I had with MicroWin about 10 years ago, but maybe it will help.
I had been debugging a program and hadn't been 'Saving' as often as I should. I got to the end of the day, went to shut down and before I knew what I had done I had clicked on NO when it asked if I wanted to save the changes. So I had a working program in the PLC and a non-working but fully commented program on my computer. I needed to fuse the two. I opened that latest version of the program and then uploaded the working program from the PLC and it fused the two. Most of the comments were in the right places, the only time I had an issue was where I had a empty network, the comments and network title were offset by the number of empty networks. I found that if I gave the network a title of any sort it fixed the problems. Now when I program if I leave a network blank for ease of reading I label it at 'Blank'. Just in case that finger goes to No instead of Yes to the save the changes question.
Bryan
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
264
I have a strange question: If i need to replace a working S7-216 supplyed with a machine from Asia, can i use the same microwin software as i...
4,229
hello is what you use the simulator s7 200 microwin? it works perfectly. but if we add an input / output card, when loading the program will have...
2,258
Hello everyone.As title says i have a small file of an packing machine done with an S7-200 cpu that i cannot open with S7 recent software.I only...
2,323
Hi , can anyone help me please. Can I comunicate through microwin with an S7-200 using PC Adaptor V5.1 6ES7 972-OCA23-OXAO ? If yes can you please...
1,811
