Migration PV550 to PVP600 on RIO
May 2012
Comayagua
Currently, I am working in a migration of a PV550 RIO to PVP600 RIO (adapter RIO module 2711-RN1). In the RIO network those are a SLC 500 5/04 (1747-SN RIO scanner), a 1791-0A32 Remote IO block module and the PC550 RIO.
When the new PVP 600 is connected to the network, the block transfer values can not to be read and shows cero value on all displays. The discrete transfer is working because the bit command is working.
For testing, I prepared a SLC demo with a SLC 5/03 with 1747-SN RIO scanner. In this case the communication of the block transfer is working and the values can be read and the displays show the values.
I need your help to solve the problem occurred when the PVP600 is connected to the network whit a SLC 500 5/04 (1747-SN RIO scanner) and 1791-0A32 Remote IO block module.
I will be gratefully for your help.
Hi everyone, i have a Siemens S7-300 Cpu 314C-2 DP with several cards of i/o and servos my laptop has TIA version 16 and 17 loaded and...
165
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
596
Hi All, We have a number of old discontinued 1756-L1 PLC systems that we are trying to support but recognize that we need to start preparing to...
975
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
945
