Milltronics Integrator (Weigh Scale) to Projector
KristienP
Jan 2015
Nova Scotia
44
[Siemens] Milltronics WD600 and Milltronics BW500
A process engineer has asked to have his weigh scale data displayed on the wall, next to the equipment, via a projector.
I'm at a loss for options.. at least affordable options. Is there a simple way to display a 4-20ma signal without a PLC / HMI software and a PC? I'm sure there are small displays, but they want it to be a large display, so it can be seen from a distance.
They have FactoryTalk/AB throughout the plant. The first thing that comes to mind is getting a cheap PC, hooking a projector up to it, and using FT ViewPoint to access a single HMI display with the Weigh Scale data on it. But that's going to cost him a few thousand dollars.
The BW500 can also connect to the Dolphin Plus software, but that seems to be more a configuration tool than monitoring software. I haven't actually used it, so I'm not sure on its capabilities.
Run the 4-20mA signal to a large display:
The bottom one is 14" wide to give you some idea of size
gclshortt
Thanks for the suggestions, but it's not exactly what I'm looking for.
Their plant floor already has an assortment of AB PLCs (various skid packages) and nothing is networked together. We're working towards having everything connected, but it's going to take some time, and money. I don't want to add another stand-alone PLC if I can help it.
danw
Those just might work. It's simple and won't cost a bunch. I didn't realize you could get large ones.. thanks!
Hello all, My problem is I'm trying to communicate Modbus ASCII with a Milltronics BW500 integrator from a custom microcontroller board through a...
1,253
Hi, For some reason I cannot read data from the OCM 3 Milltronics with the redlion PTV. I tried it with the Hyperterminal and everything works...
4,308
Hi guys, would someone please help me to understand and explain what are settings bandwidth and integrator bandwidth do with my servo in...
138
For nostalgic reasons does anyone know the model number for the DEC VMS computer that fits into the Pyramid Rack? I could only find the OS tapes...
1,022
I just want to let everyone know I did it! I am now officially an integrator for Turin robots out of China and have made my first sale of 5 of...
1,100
