Mini PLC OPC app
DDV
Jul 2006
Stellenbosch
187
Good day most esteemed members, lurkers and other interested parties. I have an application where I need to monitor only 2 digital inputs and control one digital output. I need to pull this data into an OPC for use with 3rd party software. It can be a plc or non plc solution, perhaps SoftLogic or a PCI controller card, cost is an issue, I am currently using a Simatic S7-200 PLC with a Ethernet module connecting to Simatic PC Access OPC software.
Any ideas would be greatly appreciated. Like I said cost is a factor, so it does not have to be a Siemens solution.
Thank you
One of the important questions is how you need to connect it to the PC. If it's far away on a LAN or WAN network, then Ethernet and TCP/IP are probably part of the solution. If it's on the desk next to the computer, then RS232 or USB are cheap and simple.
If I were pursuing an Allen-Bradley solution, I'd get a MicroLogix 1000 10-point controller, connect it to the serial port, and use Software Toolbox, KepServer, or RSLinx Single Node as the OPC server.
A Modicon solution using the Twido mini-controller could use a Software Toolbox or KepServer or other Modbus OPC Server.
Are you building just one of these, or hundreds ? Are they going to be installed in SA or elsewhere ?
What are the voltages for the Inputs and Outputs ?
Thank you Ken, here are my responses, your input would be greatly appreciated
I connect the plc to a HMI computer (witch is a wafer lx 800, embedded pc) with a 8.4 inc touch screen, the data from the plc must then be read via Ethernet to a server with the opc and 3rd party software.
I will look into both these options, thank you.
I need about 35 of these, all installed in SA. So using a full plc is not really a option, as it pushes the cost up per line. The IO count will never change, it will always be 2 inputs and one output being monitored and controlled.
All 24vdc
DDV,
Because you will require communication back to a PC, a smart relay will not be an option.
A micro PLC will probably be best. There are OPC drivers for just about any controller. You will need to determine what is best for your application.
We offer a small unit called the Smart-PAK that will also fit your application. More information can be found at www.entertron.com/smart-pak.htm Our communication protocol is ModBus RTU, for which OPC drivers are available.
Hope this helps,
God Bless,
Thank you Stephen, if the price is right, this would definitely be my solution. I will send you my details in a mail to your address provided (I hope his is in order?).
We can then take it from there.
Thank you
Dirk
You got me there, i would first have to google pic to understand what the hell it is.
Klink interesant!! Jogals jammer oor die krieket......
Very nice, but my electronic knowledge falls a bit short here, I don’t mind doing some development work, but this is a bit high level, at least with a plc the basics are there. Do you get a opc for this, and what software would I use for programming?
Do you have some diy projects, or diagrams?
In Midrand there's Communica, who have a PIC programming kit, which can be self assembled (minor soldering) or most electronic shops, should also come with sample app.
A PIC forms part of a lot of circuits which we are not aware of, for example DALI based dimmers and ballasts merely have PICs in them to handle the dimming and communication. DMX for stage lighting and clubs etc also utilises PICs for the comms and logic...
Worth while checking out cause if you buy, for example, a DALI based controller you're in for at least R5k. But the PIC to do the job costs +- R60.
I'm sure you can find a guy in varsity there willing to put the project together for you pretty inexpensively.
Just a thought.
example sites:
www.communica.co.za
www.electronics123.co.za (download their catalogue - they may have something in there)
Thanks man, I will look into it, I wouldn’t mind putting something inexpensive together for this project. You sound quite knowledgeable? You not interested in the job?
Anyone used an EZ Automation plc/hmi? I'd like to utilize the RTC and need assistance on how to use it in the ladder logic.
1,266
Mini PLC Specifications: 12 Digital Input 7 Relay Digital Output 8 Analog Input 1 RS232 to USB Port Mini PLC Contents: Control board + USB cable...
2,503
I have been tasked with a job to count the number of people in a site basement and display this information to the sites control room. Currently...
2,688
1772-LXP Mini PLC/2. Power supply is built into the CPU module. Can this be powered up without a chassis to preload a program? Has anyone...
1,393
I have a home automation project and am trying to pick a mini (low budget) PLC. What I need: 3 analog inputs and 1 digital input 1 analog output 2...
23
7,358
