Mitsi GT1020-LBD2 Micro HMI
dave_gibson
Oct 2008
Sunderland
Greetings,
I have a Mitsi GT1020-LBD2 mirco HMI which I am looking to connect to a Mitsi FX0N PLC.
Does anybody have any ideas on the cable required to do this??
Any help gratefully recieved.
Cheers.
Hi Dave,
The GOT 1020 has three serial cables of different lengths that enable you to connect from the mini D 8 pin socket on the FX CPU to the RS232 on the GOT itself. The part numbers and list prices are below:-
GT10-C10R4-8PGT1020/1030 to FXCPU communication cable RS422, length 1m, Mini-DIN 8-pin plug£14.00GT10-C30R4-8PGT1020/1030 to FXCPU communication cable RS422, length 3m, Mini-DIN 8-pin plug£19.00GT10-C100R4-8PGT1020/1030 to FXCPU communication cable RS422, length 10m, Mini-DIN 8-pin plug£36.00
There are also options for RS422 if you need the length.
Hope this helps,
Cheers
Scott
Tycon Automation Ltd.
www.tyconautomation.co.uk
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,081
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,215
Hi all, I'm not all that clued up on GX Developer with A series CPU. I have an Ethernet module A1SJ71E71N3-T and for the life of me I cant...
1,416
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,829
Hi, I have just wired up (might be incorrect) a Q Series PLC with an Input Card GX40-S1 and an Output Card GY40P. my issue is now in software I...
1,586
