Mitsi Mines
If you set it smaller than the size of the program - then oops yes you will lose all steps after the allocated size.
If you set it larger, and other memory allocation allows it - then you will lose nothing and gain the extra program memory. (which I presume you are after) - do a check and if you get no errors its ok
Not Mitsi, but other brands that have memory allocations. You only allocate as much as needed, that way when you need a particular section increased, you do not have to de-cipher which allocations can be reduced.
On a side note, if the PLC allows you 8k, and you aren't using anything else, why on earth would somebody want to limit themselves to 5k?
In old Medoc times I've done this on FX-series to reduce download time.
Medoc always transferred entire size allocated to the program memory, whatever the program size was.
Do not know about GX-Developer, but believe it behaves similarly, as the download protocol should be a property of the PLC, not of the programming software.
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,081
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,215
Hi all, I'm not all that clued up on GX Developer with A series CPU. I have an Ethernet module A1SJ71E71N3-T and for the life of me I cant...
1,416
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,831
Hi, I have just wired up (might be incorrect) a Q Series PLC with an Input Card GX40-S1 and an Output Card GY40P. my issue is now in software I...
1,586
