Mitsi PLC's and clocks
AndEdtec
Apr 2002
Wales
78
Clocks on FXon , FX2u, A1s ,
Thanks for your replys on my recent post about setting up a clock.
I have been doing some work on this and found that out of 6 mitsi plc's i have only 3 have RTC's.
The thing I found frustating is the 3 plc's that have been here for years have them. Which are A1S(S1) , A1SJ, and i think the other is an FX2C.
With the A1S series you have to use D9026 and D9027 and it stores the time in BCD but I'm can't work out how to do it. Help !!
With the fx2c it's the same as the FX2n and uses the TRD and puts the times in lovely data reg's, much easier.
As for the FX on, I need the FX RTC and a battery, this costs £100 a machine and I have 4.
Would it be possible to make a clock with BCD or timers and counters?
Andy.
Yes it's possible to make your own clock in the Fxon
M 8013 pulses ever seconds
M 8014 pulses ever minute
you can use these pulses to trigger timers,counter or D registers, the choice is yours.
Lightning uk
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,833
Can some one please tell me how to connect the two items above. So far i have random data in my (d) regs on the hmi. And its all the same number...
1,065
Hello all I am about to buy in a new piece of equipment for our factory. It is a pressure testing rig for the testing of toughened glass. The...
2,082
I am using a Q series mitsi PLC in a new panel and want to communicate/ talk to an old existing PLC which is an FX2n mr-ds is this possible or...
1,678
Hi fellas, I have a Mitsubishi Q02 PLC and i need to setup a PID loop. I have downloaded the manual from mitsubishi and used there programming...
2,584
