PLC choice. Mitsi or Fanuc?
Mech_n00b
Sep 2012
Birmingham
Hello all
I am about to buy in a new piece of equipment for our factory. It is a pressure testing rig for the testing of toughened glass. The intention of the piece of equipment is to identify any flaws in the glass as toughened glass with defects will explode under the applied pressure.
The design is complete and now I have a choice of two pieces of PLC software to run it. My choices are Mitsubishi or Funac as these are already on site but are dealt with by external contractors.
I have a small amount of knowledge surrounding PLC's but I would like to know which people think may be more suitable.
This is my first major engineering project and I keen to get all aspects of the design perfect.
Thanks in advance
Mech_n00b
Both vendors make a wide range of PLC models. One of them is almost certain to fill your needs. Your choice should be made based on which local reseller offers a level of support that you're comfortable with. You could also evaluate both programming software packages to decide which one seems to you to be more intuitive.
Incidentally, as far as I know, Fanuc does not offer a line of PLCs. The product line formerly sold under the GE/Fanuc (or Fanuc/GE) label is now solely under GE Intelligent Platforms (GEIP). The joint venture betwee GE and Fanuc expired a few years ago.
Hi Steve
The Fanuc range is a rebadged PLC and has actually changed its type in the past - stick with Mits = very easy to learn
Hello all
Thanks in advance
Mech_n00b
I agree with Steve's analysis.
Get quotes from your Integrators giving them these two options and see what comes back from them. But specify the GE-IP PAC or RXi platform product line to get the latest technology.
NO mate - I know it used to be Hitachi many years ago and Now?? no Idea
Hello, Thanks in advance for your input. I am building a simple alarm panel. It has 8 magnetic door switches and 8 corresponding 4mm leds on...
17
3,462
I need to replace an AB PLC. Its an older 2/02 that has only 2 X 16pt 120VAC Input cards (1771-IAD) 1 X 16pt 120VAC output card. (1771-AOD)...
4,328
Hi all, My company wants to send a co-worker to a PLC course. We use Allen Bradley PLCs. What do you recommend? I know there are PLC courses...
2,324
Hi everyone! I'm a newbie in a PLC field, and I want to study WAGO controllers. Just for my own purpose at the beginning. I want to control some...
4,880
Hello gang i have to make controls panel for a Modicon lover company and would like to get your suggestion about which product to use i have 3...
1,674
