daveincorpus
Hello,
Thanks in advance for your input.
I am building a simple alarm panel. It has 8 magnetic door switches and 8 corresponding 4mm leds on panel. The only other load is a sonalarm buzzer.
the only other input is a normally open contact that will close to turn on alarm, and a silence button. When alarm outputs I want the silence button to kill audible for ten minutes then reset. I want the led (visual) alarms to remain on constant until condition is fixed.
I am trying to choose a simple, cost effective, easy to program, plc for this function.
I can run 120vac to unit or install a din rail mounted 24vdc power supply.
Again, thanks for your expertise.
