So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the water or not.
This is a blank GE90-30 that I salvaged from a lathe barfeeder. I know the barfeeder had some software issue, but it wasn't cost effective to try and get it running, so it was getting scrapped. Most likely it was a PLC issue but I don't know.
I have the PLC hooked up to my computer, it talks to proficy machine edition 7.0 without issues. I brute forced the original OEM key, which was surprisingly easy.
My problem is that I cannot get this thing to register any input into the %I table.
The setup:
3CHS397J - 5 slot base
Power Supply: IC693PWR331E
CPU: IC693CPU360-EL
I/O Link Master: IC693BEM321G
Discreet Input Module: IC693MDL655F
Discreet Output Module: IC693MDL753F
I'm only focusing on the IC693MDL655 input module right now, just to be sure that I have any inputs that show life in proficy.
I've wiped the memory of the PLC and only downloaded a basic hardware setup into it from proficy. I have a cable strip with wires going into the first few channels of the input module. When I put 24v across any of the input wires, the corresponding number lights up on the front of the input module itself. Seemingly every channel is working according to those lights.
I do not ever get any update on the bit values in the %I table in proficy when I'm manipulating the inputs.
My question, since I'm still an absolute newbie with proficy: Do I need to create any logic or variables in proficy and download those into the PLC for the %I table to get updated when an input is active? Should they not just turn from 0 to 1 at the correctly defined %I start register when a discreet input is on or off?
The setup:
CPU: IC693CPU360-EL
