new plc beginner need help
yeungpakkei
May 2019
canada
hello everyone,
I have a siemens s7-1200 that is dismantle from a worksite. I want to learn writing program. however, it's locked and need a password to do any action like reset. I searched online the only way is use MMC to clear all the memory on it but I'm not sure it can work or not. Anyone can tell me how to make it easy or I need to spend $70 to get a MMC to solve it.
Thank you everyone
Fairly certain you can use TIA portal to factor reset the device.
Although I've never tried with a password protected device.
Hi Yeungpakkei, welcome to the forum!
The only way to do this is by using a memory card.
You mention you got this unit from work, maybe you can borrow a memory card?
Thanks for you reply, this is dismantle from worksite and is a part of gas sensor in chiller room. I tried to reset in TIA, but program can't reset. And I connect it again it appeared program blocks but locked.
So where is the best way to get the cheapest MMC?
First I'm am using the logixpro trial version form the learning pit. I'm having some problems with a program. I need some help. It would be...
2,927
I'm new to this board, but it's great!! A lot of knowledge floating around. I work as an instrumentation/electrical controls tech, and...
6,861
So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the...
115
Hi, I am looking on PLCs to make automations in a greenhouse (30x90 feet) in Canada, Québec. The goal is to start a heating, move rollup motors...
46
16,987
How do you code it to when you push a button attached to X001, it turns on Y001. Then, the next time you push the button attached to X001 it...
1,612
