Mitsibishi F1 upload and convert to FX1N
Mar 2009
Leeds
49
I've got the task of uploading the program off a F1-30MR/ES PLC and converting it to download onto a new FX1N-40MR replacement.
I've aquired a copy of Medoc 2.4 which seams to run ok on XP.
I've loaned the programming kit for the F1 a F2-20GF1 unit and the SC-03-S1 lead to connect to PC.
I'm planning on uploading the program into medoc save the project and then import this into GX Developer 8.
I understand that the IO addressing is different. So as the F1's inputs are addressed as 400-407,410-413,500-503 these need to be changed to X0-X7,X10-X17,X20-X27 for the FX1N. The outputs for F1 are 430-437,530-535 so need changing to Y0-Y7,Y10-Y17 for the FX1N. Taking into account the different output groupings for wiring.
I've had ago using MEDOC to upload a program off an old FX0S and managed imported this sucessfully into GX developer and download this to the FX1N.
My question is will GX developer import the code from the F1 and will it then just a a case of doing a search and replace on the old IO tags for the new ones as I've decribed above. If it is will there be any other program memory readdressing to be done.
I've only going to get acces to the F1 when I visit site and am not certain on the complexity of the code untill I go but was hoping to do the conversion and plc replacement with just one site visit.
Thanks for any info given.
As far as I can remember (and it has been a very long time since I worked with an F1) It is not just the I/O addressing that is different but all the functions too.
Functions like counters and maybe timers are just called FNC 201 etc.
I had an old brown mitsubishi book with them all in and remember giving up and rewriting the code anew.
I have a mitsubishi q series plc. I have logic programed that counts parts cycle times etc. If power is cycled to the cell all data is lost...
1,599
Mitsibishi First time: Math with Reals ?? I'm trying this little LAD program with some Math in it. I've red that real numbers have to be entered...
1,957
HI I am looking at providing a ramped output from a fx3u-4da.I have looked at the ramp function which works on number of scans to the set value...
1,677
HI everybody, this is my first post on here, I have 2 Omron NS8 TV00 V2 hmi's that i need to connect to a pair of mitsubishi plc's it is my first...
2,269
Hi all, new to the forum and plcs.my work have aquired the above plc as a start to programming.have been doing simple logic control and would like...
1,371
