mitsibishi FR-40-ER communications
bob1371
Mar 2003
Southern Indiana
355
Hello,
I have been given the task of finding a way to communicate with this plc. (mitsibishi FR-40-ER) I have the Medoc software.
I also have an interface module that snaps right onto the PLC. I have the cable from it going into a Converter (rs422 to something, cant read it) This converter has a mini jack on it for a 12 volt power input. From this point I am told the converter plugs into an adapter (which I dont have) :rolleyes: and then into a parallel to serial interface (which I do have). :)
Coming from this interface is a ribbon cable with a rectangular plug that I assume needs an adapter to plug into the computer.
I appologize that I cannot give more info. I was able to find on person at work that remembered seeing this mess hooked up once and that was about 5 yrs ago. banghead
Any help is greatly appreciated.
Thanks,
Bob
bonkhead
Any thoughts at all? Should we just plan on replacing these? We have 15 CNC machines that use these in thier safety panels.
thanks
bob
Still interested in a anwser ??
Tommorow I'm able to find out how you should connect.
I'm also working a lot with old PLC's. Museum pieces....:>) :p
Greatings JV
Check with your local Mitsubishi office. Since you already have the part that plugs into the plc I believe all you need is a P/N PCX-KIT-1
and it sounds like you already have some parts of that kit.
MItsubishi
I have a mitsubishi q series plc. I have logic programed that counts parts cycle times etc. If power is cycled to the cell all data is lost...
1,599
Mitsibishi First time: Math with Reals ?? I'm trying this little LAD program with some Math in it. I've red that real numbers have to be entered...
1,955
HI I am looking at providing a ramped output from a fx3u-4da.I have looked at the ramp function which works on number of scans to the set value...
1,676
HI everybody, this is my first post on here, I have 2 Omron NS8 TV00 V2 hmi's that i need to connect to a pair of mitsubishi plc's it is my first...
2,269
I've got the task of uploading the program off a F1-30MR/ES PLC and converting it to download onto a new FX1N-40MR replacement. I've aquired a...
2,212
