Mitsubishi A2 Ethernet Comms
Densam
Apr 2005
113
Hi all I can just about to read and program in GX. What we have in our plant is a lot of A2 series dotted around when there is a fault I have to pick my laptop and go into site. I want to link these plcs to the network. I have never configured IOs before. I'm used to Allen Bradley stuff. I have an empty slot on my chassis. Can someone give me a heads up on how to configure this. I have tried to attach an image. thanks
seems a lot of money time and effort simply because you dont want to walk
is there any other reason you need ethernet
Yes, some a2 are on scada using factory talk view se. So to make the whole system viewable I want to add4 A Series. Like I said I have never configured these. At the moment I am reading GX Developer manual i'm struggling. I have Ethernet cards in our stores and spare slots on chassis but need to have good know before I make a mess.
Hoping that some one can help me setting up socket communications between two Q03 CPU's with built in ethernet ports. I want to communicate...
4,857
Hi All, I was wondering if someone here might have had to do this. I have to read a portion of data (200 words'ish) from the memory of a...
4,569
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
860
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,817
Hello, I have a mitsubishi A800 drive with A8NEIP_2P that I'm trying to communicate with AB Ethernet/IP Card 1756 ENBT/A. I have everything setup...
1,317
