Mitsubishi ACPU series PLC
tabrez
Sep 2004
aurangabad
27
I have a situation. I am using Mitsubishi PLC to dial RTUs at several pumping Stations. The number comes from MX32 (Fix32 based HMI) via Text block. In A2AS CPU, it reaches register D:42 and then is parsed into D42,43 and 44 before being processed (conversion into HEX and back). Recently, the numbers have been prefixed by 17. The Scada accepts but returns first 6 digits. Simply because the registers in sequence are three only. Simply adding another register, say D:41, hasn't helped. I tried adding 17 to an ATDT command, existing in register D:101, that too didn't help. Oh, yes I have done intelligent modifications. I.e. shifted registers as required after using D41 or D100 instead. None method is working. The number I get in the last register after which it passes to Modem still is 6 digits.
The Modem Controller, used as interface between PLC processor A2AS and Modem is (A1SJ71VC24-R2) while Modem is (A1S).
Does Modem in itself has facility to prefix a number? That would make my job easier as there are 100 pumping stations. Or whether Modem Controller can offer this facility.
SOS
We have a Mitsubishi Q2a that is not moving data to some of the R registers. This started after the power was removed from the machine for several...
1,433
Anybody ever connect to Mitsi ACPU via an MTA HMI? If so what is the trick to setting up the comms?
1,604
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
39
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
