Mitsubishi device Assignment
CyrusTheVirus
Feb 2008
UK
39
Hello,
Can anyone point me in the direction of a table which will tell me what all the device assignments are. i.e
I know that X is input and Y is output but there are many more.
Specifically, I need to know what K, L, D and H variables are
Thanks craig but realy struggling finding this.
Do the device names change when using different CPU's? I can find a million examples of how to use instructions but not memory areas!
I am assuming now that k is constant, M is internal bit address and D is internal byte address
Ive still no idea of H, B and L(Long??)
D=Data register of any length.
M=Bit.
T=Timer present value word or Done contact.
C=Counter present value or Done contact.
K=Decimal signed constant.
H=Hexadecimal contstant.
S=State relay bit.
P=Jump or subroutine label.
I=Interrupt label.
V,Z=Index registers.
There are no B or L devices in Mitsubishi.
These may be data types for GX Developer.
Thanks Sergei,
Thats what I was after. Still cant find it in the manuals. I must be searching for the wrong thing
If you are using a Q series CPU - B variables are "link" relays used for networking.
I had the same problem as you when i started - how many different types of memory do mitsubishi need!
I also loath the manuals - I can never find exactly what i need without looking through more than one manual on the subject.
I like the PLC's though...
If you are using GX Dev then create a project with the type of plc you are using, go to plc parameter & it will show you most of the bits & registers (note not all) in general the M bits go from M0 to 512 (there are more but for most like FX thats all you will need) D 0-512 special relays are in the 8000 range also you can set the ranges that are retentative i.e. D 256 to 512 etc.
the mitsubishi website does have many manuals also if in GX Dev then in the help select speacial relays, FX or Q & it gives you a list of the functions like always on first scan etc.
The I/O range is fixed i.e. when you plug in an expansion card & you have say an FX2N16 then the onboard I/O = X0.0 to X0.7 Y0.0 to Y0.7 so the next card would be X(or Y) 1.0 - 1.7
Special function modules start at slot 0, 1, 2, 3 etc.
Sorry for the basic question... I've had a look through the Q68AD-G (analogue input to digital converter), and I'm trying to find out if the...
3,075
Hi everybody! Im meet a big problem that my PLC is FX1n 24Mr and he has an Rs422 Com port, and the HMI is Delta TP04P series has Rs485 2w...
2,453
I understand that Red Lion has an interface product that will allow coms with a Mitsubishi processor over true TCP/IP. A local rep is supposed to...
3,701
Hello all. I uploaded a program from a FX2N-16MR using GX Developer version 5.00. The program had no device comments. I know that mits plcs do not...
1,966
hi all, I'm wondering if anyone has ever converted an Allen Bradley AOI to a Mitsubishi Function block. I's hard to find libraries from...
20
