Mitsubishi E1070 HMI Error Code
dan325
Mar 2011
Winona, MN
Using the E1070 with a FX3U Mitsubishi PLC in a machine tool application. We've used this HMI for several years with no problems. Now this:
Error code: FS_WRTR DATA ERR #4
The error occurred while running an automatic cycle with the machine, no human inputs. It has ran fine for 3 days, this is a new installation, so strange?? I had our customer cycle power on the machine and the error went away and seemed to function correctly.
Here is a link to the manual if that is any help:http://www.meau.com/Files/MA00776C.PDF
Help
Hi I would suggest refering back to your mitsi support contact. I assume you already checked the manual. Of course its fingers crossed someone here has seen it before.
The UK location wont make any difference to the error.
Because it is a new install is the HMI cable / ethernet /whatever u used well away from servo and inverter type cables and equipment ( did the installer mess up ) get your customer to send u sopme photos maybe
Cheers.
I did contact Mits as well, no quick answer from them. I sent them the project to review as well. We've used this project on 50+ machines with the E1070. Hope the find something
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
39
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
101
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
76
