Mitsubishi Fr-F700 series and modbus
There is a released Freqrol driver available for E1000-series. It should be possible for you to select it in E-Designer, if it isn't then you have probably not updated your drivers (File -> Update E1000 drivers from -> Internet). You can find more information about the driver if you click on Help -> Driver help in E-Designer.
//Supporter
Greetings all, I am seeking some help and direction on controlling a Mitsubishi F700 VFD from my Red Lion DSP. I have been able to read data from...
2,383
Hello All, Anyone out there have experience with Mitsubishi F700 VFDS? I am writing a duplex pump application using two F700's. PLC is a Idec...
2,259
Hello all, Hopefully someone can help me with the setup of modbus-rtu between a Idec Microsmart PLC and a Mitsubishi F700 VFD. My project is to...
3,042
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
37
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
37
