Help with Mitsubishi F700 Drive RS-485 communications
todell
Feb 2009
CA
18
Hello All,
Anyone out there have experience with Mitsubishi F700 VFDS? I am writing a duplex pump application using two F700's. PLC is a Idec FC5A-D16RS1 with FC4A-HPC3 RS-485 module.
Presently I have the drive communication parameters set at:
79=6
340=12
339=1
338=0
550=1
551=2
549=1
331=1
332=96 9600 baud
The rest of the 485 parameters I have left default.
I have the PLC port 2 set for Modbus-RTU and have built a data reqest table with read holding registers from the drive.
The system needs to start from communications and speed control is the drives PID.
I have scoured the manuals for hours and cant seem to get it to work.
Any help would be greatly appreciated!!!!
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,895
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
503
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,580
I have the FX2N-4DA analog output module and I am trying to send a value to one of the channels to give me a 0-10v output. Does anyone have any...
1,396
