MITSUBISHI FX-1N-24 MT PLC for servo drive programming instructions
hinddhindsa
Mar 2013
www.plckart.com
193
Hi, all friends, I am developing an slicer machine program, where servo drive has to move 20 mm (whatever is set on hmi) distance and again it should stop for some time and then keep on continuing the process. i have mitsubishi fx-1n-24 mt PLC. for movement of servo i am using PLSY {S1 S2 Y0} instruction, where i set S1=k50 , S2= K30000 , Could you help me to understand that how can i increase the speed of my servo motor, which is connected to DELTA SERVO Amplifier ASDA-B2. my motor moves very slowly, i need it to run faster, how can i increase the servo motor at high speed, what values i should vary in PLSY.
is there any other instruction for servo movement in MITSUBISHI PLC PROGRAM.
Please guide urgently.
Big thanks in advance, Hind
more information.
i have used Y0 and Y1 output of PLC, for forward and reverse direction of servo.drive movement everything is ok. only need some speed increment.
when my motor is moving some sound is coming from motor.
we have a pipe cutting machine that was out of use for a long time, so the battery for plc was gone. I replaced plc battery, but now both servo...
1,014
Hi guys, Any one know about this PLC, please let me know. I am interested in how to reset the dynamic breaking of Mitsubishi Servo motor. Best...
1,393
I tried to read the actual pulse in D8140. Its shows the current pulse value. but want to compare that pulse for to start motor. for example:i...
2,183
Hello everybody, I'm new here, both on this forum and world of PLC programming; got a student job last week at company which uses Mitsubishi...
28
14,002
MITSUBISHI FX3S SERIES PLC TO RUN SERVO MOTOR ?? I have FX3S series PLC which have two axis control. I have application to run only in forward...
3,990
