hello
doomsword , i working on a FX5 plc with a fx55-40SSC-S module. im working on a project for indexing with 2 axis.
but by the moment i just learn how to move in jog mode lol!!. i try to use the tables much of the configuration on the gxw3 for the module its the couse of the "issues".
Richg now im working in how to make a home return in order to use the data position table for the axis.
i hope you find your solution.
best regards
Hello, I managed to get much understanding of that module + I'm getting two day training for that module in a week (I had few 'trainings' and I think it's just mostly for impressing people buying Mitsu equipment with flashy videos. But I'll make them spit out real knowledge). After a month or so dealing with it I can say that anything related to motion isn't easy.
We got that machine in my office, I managed to get it running, logic that drives the servo works. I managed to set synchronization, after coming to deal with painful shortcomings of that module:
I had to set a virtual axis just to unlock second high speed input. Then I came to realize cycle time of that module is 1.77ms, which might not be fast enough (they talked about response time of 1ms, I now think this is pure fantasy).
I managed to make everything run on module, mostly by using address mode for both virtual clutches, since you can't start and stop clutch using separate signal for each action, I had to make some tricks to make it run properly.
I use PLC to determine start/stop of clutches in advance, since real 'real-time' operation is impossible, I write that information 1 labeling cycle before it's executed since I don't have enough time.
And finally, yesterday and today I managed to set up some kind of conveyor belt simulation, where i use other motor to rotate synchronous encoder which simulates impulses from conveyor. And it works, those two things are in sync.
I managed to make it to run nicely up until 25-30% of required max speed. It still runs decently up to 35-40% of max speed. Last few hours of this work day I spent analyzing responses of system in MR Configurator2.
And I came to conclusion that 750W isn't enough, this thing can't make enough torque to counter dynamic torque generated when accel/decel-ing this machine. At least few kW in my opinion. Will ask boss about this tomorrow, I'm pretty sure you can't accelerate this thing in 1ms (or even 5-10ms) to 100% of max speed. Also this problem is analyzed by experienced Mitsu motion engineer in Poland (center of Eastern European hub), first thing he asked was how strong is our motor.
Feel free to ask me questions, I'm anyways intended to be a Mitsu tech support for my country.
