Mitsubishi FX2NC
cjh
Mar 2003
Cumming, GA
235
Anybody ever see a problem where the error LED turns on when you plug in the SC-09 programming cable? I can't connect to the PLC either. If I take the cable out, the error LED goes away???
that sounds interesting...
i didn't use FX2NC but SC09 should be the right cable.
are you sure this cable is ok? SC09 draws 5V power from the
PLC (used for converter chips inside the bulky end of the SC09).
if the cable is damaged and you plug it to plc, it is quite
possible that plc detects it and acts as you have described.
I feel pretty confident that the cable is fine. I can plug it into a FX2N-32MT and it works fine. It's only the FX2NC that it doesn't like.
We have encoutered a similar problem before.
The problem was with the stacks of printed ccts inside the PLC.
When we would PUSH the DIN connector in place it would short cct the power internal power supply. We we would PULL it out the short was disengaged.
We only found it when we tryed to make one good unit out of many dead ones. That was 6 month later :)
We screwed and snapped the parts back in place and all was OK.
This is a wild guess but you can try!
Open it and reconnect the SC09 cable while monitoring the 5 Vdc supply.
Nice one Pierre, and I believe it will be the fault.
I was stumped with the problem then read your reply and remembered I too had a similar fault a few years back.
All of the lights were going off on the front of the plc, but give it a squeeze (yeah, a squeeze with fingers on top and thumb underneath) and it all came back on and ran for weeks before happening again.
I took it to bits several times but found no particulat fault - in the end just did what I should have done at the start :) - swapped it out.
That sounds just like problems I had with my Keyence vision system
or J2S Mitsubishi servos... They sure squeeze everything in and
make it look nice but not robust.
I've had a very similar problem with these PLCs. When I have an E50/100 series screen connected the screen would sometimes turn off on it's own. We found out that it was losing power at the PLC connector. We had to put a small 5v power supply just for the screen since the supply from the plc was not reliable.
I have a remote input terminal block (FX-16E-TB/UL) that appears to have failed. Can I replace this block with like kind without PLC configuration?
1,544
Dear all I am trying to get the decimal value like 1.2 or 2.5 into Mitsubishi FX2N PLC (like D40) from HMI software NI Lookout6.2 for...
5,723
I have a project where the FX2NC looks like the ideal solution. However, I need to connect the a pc (for programming) and a touchscreen at the...
3,727
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
51
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
46
