Mitsubishi FX3G rs232 communication via 422 Programming port.
nvanzyl
Jan 2011
Pretoria
Hi All.
Wonder if some1 can help me. Im using a FX3G mitsubishi PLC and want to communicate via the RS422 coms port instead of adding a 232-BD adaptor. Is this posasble?
Thanks,
Nic
Hello,
Maybe.
IIRC Mac's had 422 ports and you could ground the + receive pin and if the other device responded to TTL voltage levels it would work. I could be wrong on the pin. Search the web and I am sure you will find the pin out.
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
126
I have a client with a Mitsubishi FX3G-60MT PLC the machine is Chinese only 5 years old and surprisingly its build is good. however.... its PLC...
3,402
Hello Friends I need to communicate these devices. Is it possible? How can I do that? The marker supports RS232C and Ethernet, which could be...
1,162
Hi all, I am totally new to the PLC world and I already face a major obstacle :) I am trying to control a really simple pneumatic system using...
1,468
Evening all, Currently stuck in the office trying to get a working bit of program together for a Mitsubishi FX3G to control two FR-D720S...
1,696
