Mitsubishi GT Designer
1mess
Dec 2011
Barrie
Anyone know how to use a different pop up keypad for numerical entry.
I would like to have a custom keypad other than the default one.
I think I have to use Key codes but I am unsure where the key code values are stored as there is no destination device.
Hello,
You can make your own by creating a dialog window screen the size you want the keypad to be. Then you drop in all the characters you want using key code switches. You can make the appearance and text whatever you like. Then in your project settings, under environmental settings, key window, select user created key window and reference the window screen number that corresponds to your new keypad.
Hope this helps,
Dave
Thanks Dave. Is it possible to keep the default as well as a custom keypad or are we limited to one single design. I am adding screens to a customer's already existing project and did not want to impact what they already have existing.
Marc
I believe so......I think you can go into the properties of each individual screen and prioritize the screen over the project settings.
Hope this helps
Thanks for all your help Dave. With your help I have been able to get things working the way I intended.
Marc
I have a customer that has a GT1575-VNBA and I think they are using GT Designer. They have the software and program for both the HMI and the PLC...
2,317
Hopefully someone has had more experience in this than I have. I was tasked with making a recipe function for a project. I've done so based on...
2,693
Hi id like to connect my wago controller with mitsubishi hmi and im using codesys 2.3 and gx designer 3. Id like to know how i know what register...
4,668
I am trying to back up a Mitsubishi GOT A970 with GT Designer 2 Classic. The back up seems to go fine but when I open up some of the screens some...
1,464
Anyone know if there is a way of changing the PLC addresses the HMI is using in simulator mode? Seems a bit limited otherwise.
3,334
