Mitsubishi GX Works3/FactoryIO & C# Connection
diamonddog
Mar 2023
Berlin
Hello,
As a newbie to PLCs, I have two issues.
1) I connected Mitsubishi GX Works3 and Factory IO on a project I am working on. But when I do a read/write operation on GX Works3 variables using MX OPC Configurator over C#, I immediately get a "Connection number acquisition error" error. For this reason, my variable updates via MX OPC are not reflected in Factory IO and I cannot use the simulation properly.
2) I'm making updates on MX OPC Configurator Tags using C#, but how can I send string type data using C#?
for example;
plc.SetDevice(string, int) // string field is for tag name, int field is for value
plc.SetDevice(string, short) // string field is for tag name, int field is for value
With the above two methods, int and short data can be sent, but I couldn't see a method offered by MX Component to send string type data
Is there anyone who has knowledge on PLCs that can help me in this regard?🤞🏻
Thanks in advance.
Not used MX component for many years, Mitsi PLC's do not really handle strings over coms directly, a String is just a bunch of D words i.e. a D word would contain the ascii value of say "AB" (If I remember rightly it is reversed).
So perhaps you would need to send them as a number of words not as a string
I found this not really looked at it but may give you some ideas.
https://www.youtube.com/watch?v=_5vSMpVfJ-I
MX Component is official Library.
You must use MX Component Version 4 or later.
This support GX Works 3.
But earlier version not support it.
If you use GX Simulator2 , and you can choise a lot of informal library.
Example, "simple gx"
This DLL has simple function.
Donwload here
https://ftp.vector.co.jp/75/96/2271/SimpleGX.zip
This DLL written in C++(Call Windows API) and VB.NET.
VB.NET Code
Dim ins As New GXSim
ins.CPU = enumCPU._Non
Dim rtn As ReturnUS = ins.ReadDeviceBlock2("D0", 10)
MsgBox(ins.UShortDis(rtn.dat, "/"))
Dim dat(960) As UShort : For i = 0 To 959 : dat(i) = i + 1 : Next
ins.WriteDeviceBlock2("D0", 960, dat)
C# Code
GXSim ins = new GXSim();
ins.CPU =(int)enumCPU._Non;
ReturnUS rtn = ins.ReadDeviceBlock2("D0",10);
MessageBox.Show(ins.UShortDis(rtn.dat,"/"));
ushort[] dat = new ushort[960];
ushort i;
for (i = 0; i < 959; i++) { dat =(ushort)(i+1) ; }
ins.WriteDeviceBlock2("D0",960,dat);
"enumCPU" means postfix in PLCtype.
example,
Q00CPU - enumCPU._Non
q26udvcpu - enumCPU.UDV
I'm absolutely stuck at this point with the recipe portion of my program. I used the default example they had on their website to create the...
1,783
Hi Guys, Who amongst us has worked on Mitsubishi FX5U with Analog extension modules and GX Works3? Please, I will need your support here...
916
Hi Friends, Please, who can tell me the Function Block used for scaling 4-20mA to say 0-200PSI in Mitsubishi GX Works3?
7,381
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
44
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
64
