Mitsubishi Instruction ---|STL|---
gbradley
Apr 2002
Corona, Ca.
1,637
I attached a .jpg of the printed ladder in question.
There is a Load, or Examine On instruction.
In between the vertical bars are the letters STL...---|STL|---
As I am entering in the instructions, I don't see an option to display ---|STL|---
How can I display this?
Or is the ---|STL|--- a completely different instruction, than ---| |---?
I entered it with a standard instruction, so I wonder if it will work the same.
All I have is a hard copy of a ladder file printed on paper.
I can't get to the processor right now, so I am writing a ladder file with GX developer.
I just ordered GX-Works2-C1 for the PLC and GT-Works3-C1 for the HMI.
In the meantime, I am practicing with the GX developer Programming and Maintenance tool version 8.25B
Hi Mate
in the old Melsec this is the MCR (master control)
melsec the contact was shown in the LHS rung @ 90 degrees
this is what it will be
Hi Mate
Sorry, I don't follow.
I don't know what the LHS rung is.
I figure that this is similar to the Stage instruction in Directsoft.
left hand side (power) rung
similar to using the AB conditional JSR routines
have a look at this PRG
imported to GX dev from Melsec
EDIT = PG 11
The original jpg looks like it is from Medoc(dos). In GX Developer you would just have a |----------[STL S10]--| and then your logic.
see attached
Is K4M101 a constant? Is K7 a constant? What does this instruction do? Thanks
19
5,177
Hi, Can anyone tell me if there is an equivalent 'truncate' function in Mitsubishi GX Works 2. Ive worked with Rockwell and Siemens for years...
23
4,668
Hi, I have always worked with Rslogix500 and I'm working on a project migrating the code from an old mitsubishi FX64MR to and slc505. I'm having...
2,530
Good morning or afternoon wherever you may be. New to Mitsubishi controls and playing around with software and the simulator. GX Works 2...
2,856
Hi everybody, I am working on a packaging machine that communicates with 2 servo drives and need a little help understanding the instruction. I...
2,163
