Mitsubishi Melsec K2N PLC
raburnett
Dec 2022
Indiana
I have an 80's PLC, Mitsubishi K2NCPU that needs replacing.
Is there a software / cable available to upload and print the current PLC program?
It's more 70' than 80's PLC. Never worked with it, but I have seen it in action, and I remember that there was programmable terminal for it. Even old DOS Medoc does not support it.
I think that it's application can't be to complicated due to small memory it has, so it should not be to complicated to write it from scratch.
As Goghie has posted, the first IDE I used was Medoc & that did not support it, the earliest programmers were either large consoles with CRT screens or handheld units, I did use some of these but never came across the "K" series so I think you are out of luck. Mitsubishi are very good at keeping their platforms interchangeable so if you manage to find some sort of printout or hand written ladder/list then it is easy to input that into the later FX series.
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
517
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
949
I have been asked to work on a Mitsubishi Melsec FX2N-80MR PLC but have no experience with Mitsubishi at all. The hope is to get online to find...
1,335
We received a cell that has a MELSEC Mitsubishi FX 2N-80MR PLC installed. We need to access the PLC program for troubleshooting and additional...
1,979
Its been a while since I've worked with a mitsu. In regards to Timer register reads and writes: Does it read the accumulator and write to the...
2,287
