Mitsubishi PLC Decimal to Hex
Gezzer07
Jul 2018
Manchester
Hi
I'm using Mitsubishi FX5U with a GOT HMI. I need to enter values on HMI in decimal format then convert to HEX for use on a Modbus RTU link.
Anyone any ideas how this can be done as I can't find an instruction.
Modbus RTU transmits the pure binary value, if you have the value stored in a PLC register, you have to transmit the bytes just as they are.
Because Modbus RTU transmit the binary value it needs all the 8 bit in a byte and it will not work in a 7 bit serial communication.
The problem will be different if it uses Modbus ASCII then value must be converted to the HEX representation in ASCII characters prior to transmit.
Dear all I am trying to get the decimal value like 1.2 or 2.5 into Mitsubishi FX2N PLC (like D40) from HMI software NI Lookout6.2 for...
5,723
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
140
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
118
