Mitsubishi PLC & GSM programming connection
putsie18
Aug 2012
Vancouver, BC
I am trying to find a GSM modem that will work with Mitsubishi Q PLC so I can make a remote connection with GX Developer to monitor and program the PLC. I have found limited information and am looking for hardware that will make this as simple as possible. I have found that Mitsubishi has a GSM modem module however I am unsure if it will work in the USA and if it supports a Q series PLCs. Your help is greatly appreciated.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
115
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
162
