Mitsubishi PLC system,
Mpoon
Sep 2004
Toronto.ont,canada
41
Mitsubishi PLC system, have intermittent communication lost, between 5 PLC CPU.
L. Err red LED flashing on the communication module QJ71BR11. checked cable, clean connector. Pin,
still happen occasionally , any one can help?
I would verify the settings on the master to ensure that there are 4 stations set on the network and the shared address parameters are all configured. Also make sure they are all set properly on the station numbers and the network number in the network parameters matches on all units. Also check the mode switch on all units.
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjklZrl9pDLAhUog4MKHXlnAlgQFggbMAA&url=http%3A%2F%2Fwww.omniray.ch%2Fmodulare-sps-system-q.html%3Ffile%3Dtl_files%2FKatalog%2FHandbuecher%2FSteuerungs-UndRegeltechnik%2FSPS-Systeme%2FModulareSteuerungen%2FSystem-Q%2FKommunikation%2FQJ71-LP21-25-G-BR11-MelsecNetHNetworkModule_UserManual-Installation_IB-080049-M.pdf&usg=AFQjCNFZlBN4ba77kAY8g-6ktMYMESeLvw&bvm=bv.115277099,d.amc
Hope this helps,
Hello everybody, I'm new here, both on this forum and world of PLC programming; got a student job last week at company which uses Mitsubishi...
28
14,046
Hello, I have a question on my HNC electrical and electronic engineering assesignment which has me stumped after hours of looking through PDF...
2,572
149
81
185
