Mitsubishi PLC to AB & Siemens Comm
deljvk
Mar 2015
angeles
21
Please I need your advice.
1. Master PLC Mitsubishi CPU-R04CPU + ETH module RJ71EN71
2. Master need to comm with AB CompactLogix 1769-L33ER & Siemens S7200 cpu224cn
Master PLC is only SLMP protocol compatible based on the manual. Kindly advise, I'm planning to have it as ethernet IP maybe using gateways, but how can I make the master do it.
Please advice.
Thanks.
JC
There is Ethernet/IP module RJ71EIP91 for Mitsubishi that is fully compliant.
With RJ71EN71 you can use Modbus TCP/IP or CC-Link IE - so you can use Modbus TCP/IP if you do not want to invest in RJ71EIP91.
Thanks for the input, well noted on this RJ71EIP91.
Yes, I thought about Modbus too, but only act as a slave only. Does it work as a master too ?
I also thought about red lion product, anyone made use of it?
Thanks.
Cheers :)
Hi! I'm new to Mitsubishi robots so please bear with me. I have a setup of an RV-7F-Q1-S15 robot with a CR750-07VQ1-1-S15 controller and a PLC...
3,348
Im trying to migrate a program from Mitsubishi to Siemens PLC using TIA PORTAL. Can anyone help me to understand and translate the logic in the...
2,888
help needed to write program to communicate siemens master drive with fx plc via rs485 or rs 232 port
2,118
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
