Mitsubishi PLC to PLC Connection using ethernet Module.,HELP
chokoy
May 2012
Manila
I need to network two plc's using QJ71E71-100.please help me on hardware and programming samples.,thankz guys.
by Searching google for "QJ71E71-100" there is a 500 page PDF too large to post.
I noted that your previous fist post was not answered.
You do need to post more detaill or what you are after as it appears you want us to do your work for you...
many of us do not like that
we will help you - BUT - you need to write some code
Thank you, im already using the manual.,theres no guide on doing the program, there were no setting for master and slave plc.,
this is my 1st time to use ethernet as comm protocol,.
yes pman.,im having problem with plc set up and program.,there's always an error on parameter and instruction,.please share infos for this
his is an advanced Q series program
have a look - it is a rock crusher
thanks iant, sorry but theres no QJ71E71-100 module on the program you've shared. i need guidance for ethernet parameter, and the instructions to use in data send and recieve,. i've tried using GP.SREAD/GP.SWRITE, but encountered errors
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
115
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
162
