Mitsubishi QJ71E71 Ethernet Module
thomas1000
Aug 2005
Wales
50
I am looking for a basic description of what the following configuration parameter are and their function in the above module.
I have read the basic and application manuals and am none the wiser.
Has anyone got a download link or a manual that explains what the following terminology referes to:-
Open system
  • Active
  • Unpassive
  • Fullpassive
  • MELSOFT connection
Fixed buffer communication
  • Procedure exist
  • No procedure
Pairing open
  • No pairs
  • Pairs
Existance confirmation
  • No confirm
  • Confirm
Thanks Crossbow for your reply,I will download the manual to see.
Myreal problem is setting up communication using fixed buffers between two ports with a Q71E71 module and Beijers E1100 HMI.
I can get the two to communicate with each other by automatic port open using port 5000 on UDP but not using fixed ports 500 and 501. I have set the HMI and PLC using varying parameters without success.
Have you set up such a system and if you have how did you achieve it.
I have made an E1101 communicate with a Q (actually with two E1101 and two Q on same network). Follow the steps as they are laid out in the E-Designer manual for the Ethernet connection. It's downloadable from www.meau.com.
Hello all. My name is Robert Siegfred. My company is TDS Automation L.L.C. I have recently been upgrading A-Series PLC to Q-Series and have been...
2,343
Hi to all, I'm trying to connect a Mitsubishi Q series PLC using a QJ71E71 Ethernet card to Kepware. I'm currently using TCP Protocol, it connects...
1,514
hi,all. now i need to develop one VB.net program to send data to Q series CPU following MC 3E protocol.and now,I can connected to E71 module...
5,835
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
