VB.NET communicate problem with Mitsubishi QJ71E71
goralliz
Jun 2008
Liverpool
hi,all.
now i need to develop one VB.net program to send data to Q series CPU following MC 3E protocol.and now,I can connected to E71 module successful,but while i tried to send data to PLC side,program response code is ok,but PLC side cant received any data.
can anybody give me some advise?
My VB code as following:(PC -> PLC,ASCII code)
Private Sub Command1_Click(ByVal eventSender As System.Object, ByVal eventArgs As System.EventArgs) Handles Command1.Click
'Connect to the Ethernet interfece module.
Dim sock As New Sockets.Socket(Sockets.AddressFamily.InterNetwork,Sockets.SocketType.Stream,Sockets.ProtocolType.Tcp)
Ajsock = sock
Dim ip As IPAddress = Dns.Resolve("192.0.1.253").AddressList(0)
Dim ipend As IPEndPoint = New IPEndPoint(ip, "8192")
Me.Ajsock.Connect(ipend)
MsgBox("Connection Completed")
State = Me.Ajsock.Connected()
End Sub
Private Sub Command2_Click(ByVal eventSender As System.Object, ByVal eventArgs As System.EventArgs) Handles Command2.Click
Dim SData As Byte()
Dim RData(256) As Byte
'Send D4001 to D4003 (3 points) with the QnA-compatible 3E frame command.
'SData = Encoding.ASCII.GetBytes("500000FF03FF000018000A14010000D*004001199512021130")
'Send the data.
Me.Ajsock.Send(SData)
MsgBox("Send completion", MsgBoxStyle.Information)
'Read the response from the PLC CPU.
Me.Ajsock.Receive(RData)
MsgBox(Encoding.ASCII.GetString(RData), MsgBoxStyle.Information)
End Sub
yes I have tried to capture tcp data by ethereal.
PC ->PLC PDU as:
PLC -> PC PDU as:
In this case I changed send message as:pC only send 1995(HEX) to D4000.
Help me to know whether the Mitsubishi Q series E71 protocol (MC 1E/3E) is synchronous (waits until the responce comes) or asynchronous protocol (sends all request and collect all responces asynchronously)?
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
351
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
230
Currently I'm working in a project, and there is a problem, we need to show what is going on with the CR30 through an app developed in VB.NET, we...
611
I have numerous 24VDC/50mA beacon/horn devices in the field. How do I convert these devices to IP based devices where each device gets an unique...
1,526
Hello, I have a mitsubishi A800 drive with A8NEIP_2P that I'm trying to communicate with AB Ethernet/IP Card 1756 ENBT/A. I have everything setup...
1,317
