Mitsubishi upgrade
Killercal
Aug 2006
Ontario
150
Has anyone use the software to convert A-series PLC program to a new Q-series PLC?
If so, what hints, tips or tricks can you share?
Thanks,
Scott
Hi
I did this a few years ago.
I remeber that the internal markers M9036 etc had to be replaced to suit the Q's and that I had to recheck the timer timebase settings.
I also removed the analog input scaling routines and used the tool for the Q analog card itself
Cheers
GX developer wil handle it OK
the analogues and other cards will give you some small issues
Just used it last week
contact Mits dealer
there is a PDF for the conversion.
Sorry but it is confidential - I can not post it
EDIT
It is also a 14Mb file
Go to www.meau.ca They have a section on their website that helps a lot. I have done many A to Q conversions including Network, analog, serial, and counting cards; have had good luck doing them all.
Hi, I going to upgrade the A Series PLC to Q series PLC but the touch screen will remain the same Can anyone help me to convert the A series...
6,708
I have an old e710 terminal and I need to upgrade the firmware to take and ethernet board. I downloaded MAC_e710_V6.10.zip from meau.com and...
4,951
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
144
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
69
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
69
