Mitsubushi & Proface HMI
profmaster
Aug 2008
Malaysia
Hi All.
I have some situation that I need help with all of you.
Please refer attachment.
Front and back HMI using same program. Its give feedback to Mitsubishi through network connection.
When production need changed recipe, they only need to change the no, and all save data will transfer to Mitsubishi PLC and Keyence PLC
Center HMI is using diff program. It is only used to conrol Keyence PLC.
My question is, how I can send the data from Front HMI to Center HMI using the network transfer.
Or, is that have other way to send the data?
Or, is that I need to used other program, such as Pro-Server?
Please give some advice. Thanks
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
39
Hi Friends Can anyone send me manual of Mitsubishi make AJ71ME81 (ME NET interface module) manual.
1,654
Hi I have an installed E1100 on a site which has a fault whereby the RTC is changing randomly, causing scheduling eerors with the process...
1,933
I am working on a program I have inherted from another one of our so called programmers at my factory. This program is quite confusing and quite...
4,034
I have recently inhereted a program written by someone else, running program test using GPP developer I found it had over one hundred errors with...
5,779
