Mix_read/ mix_write problems Prodave s7
Mar 2005
This is a call to very one ever used Prodave to manipulate the siemens s7-300 plc's.
How do you implement code in Visual basic for mix_read and mix_write.
I declared the functions in a *.bas file and want to use them just as e_field_read for example. However VB doesn't make the exe because:
Compile error:
Only public user defined types defined in public object modules can be used as parameters or return types for public procedures of class modules or as fields of public user defined types
Please can anyone post code how to use mix_read and mix_write
Thanks in advance,
Kind regards,
Bart
I have everything set up for vibration monitoring with the code in Controllogix 5000. The thing is that I am not able to read values SCADA in mm/s...
44
I have to decide between using factory talk SE and ME on 15" touchscreens. There will be 3 touchscreens all displaying the exact same displays in...
5,992
Hello, I am responsible for controls in 1 hydroelectric plant out of 3 plants that are being constructed. This is my first project with Allen...
8,837
Gents, I have a small project that is in an early stage and I need some suggestions. We have two ¾” pipes that carry water one cold one hot...
4,767
Exercise #1 -- Filling the Batch Mixing Tank From the Simulations Menu at the top of the screen, Select the Batch Mixing Simulation. Using...
6,166
