Dryhops
I have a system that is all currently 110 AC. It uses a 1769-L30ER with a 1769-PA2, and a 1769-OA8.
I need to add 4 2-wire pressure transducers that require 24v. Can this be done by adding a 1769-IF8 and then using an external power supply for the DC+ to the transducers?
I really only have experience using 24v systems and stepping up voltage with relays, not the reverse.
Thanks for your time.
