ML 1100 Input numeric value
Billmac
Apr 2013
Northants
Hello people
I'm looking for the simplest way to input a numeric value into a ML100
I need the numbers 1 to 12 this value will be used to determine how much
product is placed on a pallet . The operator should be able to change this value
to suit products ( I was thinking about using bcd thumbwheel but i don't have 8
free inputs ) any help or advice.
Billmac
One input which increases by "1" (ADD 1)the Accumulator of a CTU with a Preset of "12".
Ladder logic "inpect" the CTU/.acc value and eventually provide a CTU (RES) PB input in case the operator has had a bad day and cannot count the pushes...:ROFLMAO:
Well, the 1100 has a HMI built into it. You could use that. But if it's inside an electrical panel, it could be unsafe to allow operators inside. Use small PV Component HMI.
I was thinking about using bcd thumbwheel but i don't have 8 free inputs
You would actually only need 5 inputs. Since the tens digit is only a 0 or 1, you'd only have to wire up the first contact. (Of course, that would prevent the PLC from knowing if they set a value higher than 12.)
Thanks for the fast response
I looked at the Red Lion Hmi but it may be a bit overkill for what i'm trying to achieve but maybe as a last resort cheers , I also looked at fitting lcd counter and taking the push button ( ctu ) idea and push button to reset display counter and (ctu) , The best method would be bcd thumbwheels, I have 5 spare inputs
and only require the values from 8 to 12 but dont know anything about bcd inputs or how to incorporate into plc listing. Any assistance
Thanks for taking the time to read
Billmac
Hi
If you only need 8 to twelve and you have 5 inputs you could wire 5 switches on the panel door and wire to inputs. Then if you need 8 get the operator to turn on te first switch and label it as 8 but in the code move a valve of 8 if this I put is on. Then if the first and the second are on move 9 and so on given you what u require.
Hope this is of some good to you.
If it was me I would go with the small HMi so alarms etc could be displayed
Donnchadh
Optimate OM413.
http://www.nematron.com/products/industrial/optimate.html
136 bucks from automation direct:
http://www.automationdirect.com/adc...timate_Text_Panels/Optimate_400_Series/OP-413
Works beautifully with Micrologix. You could spend time trying to make something like a BCD thumwheel work, but at $136 you'll very quickly blow any savings. Cheap, good, fast, and professional looking. I've been using them for more than 10 years and haven't ever had a problem.
You'll need a programming cable and a PLC cable that will add 40 bucks but the price is still well worth it. Get the software from Nematron (first link) for free, don't buy it from Automationdirect.
If you really are on a cost-cutter and have to go with the BCD thumbwheel switches, get some that you can set stops in, so the "tens" digit can be locked to only allow 0 or 1.
Omron have switches that take stopper pins to limit the travel.
Billmac; said:
Hello people
Billmac
Another option...
I use a Schneider Magelis HMISTO 3.4" touchscreen to ML1400 using DF1 (or DH485 if needed).
It's on a palletizer for the operators to set the number of layers required for the pallets. Can be anywhere from 6-11 layers required depending on product.
They are programmed using Vijeo Designer, which is free for the small panels and relatively easy to use, but feature rich.
We get them from Radionics. They are listed at £205.42 at the moment. You would need the USB programming cable linked on the same page £33.00.
HMISTO511 (green/orange/red):
http://uk.rs-online.com/web/p/touch-screen-hmi-displays/7110022/
HMISTO 3.4" Data Sheet:
http://docs-europe.electrocomponents.com/webdocs/0e72/0900766b80e72692.pdf
Vijeo Designer can be downloaded from an FTP site:
Schneider Electric; said:
To download this software use an FTP client like Filezilla or a download manager like Free Download Manager
1. Go to the FTP site: ftp.fr.schneider-electric.com
2. Username: VDesigner
3. Password: VDesigner
4. Folder: VDesigner
That FTP can be slow, but it gets there.
The STO is very useful as a discrete touchscreen HMI. I'm using it, and also some of it's bigger brothers, for about 2yrs now. I've gotten quite good in Vijeo Designer.
I've attached some pics that I've taken to show it's scale and an example of the display powered on.
If you are not inclined to get into new HMI programming software for a small application like this, then certainly go with a thumbwheel or similar.
Another simple option...
  1. Use a momentary illuminated pushbutton to one input, and one output drives the lamp.
  2. Hold it down for 5 seconds to enter edit mode. This zeros the quantity and turns the lamp on solid.
  3. Pressing the button x1 sets the value=8, x2=9, x3=10, x4=11, x5=12. Each press and release of the button the lamp flashes twice to indicate the value has incremented and returns to solid on. If they loose their way, press for 5 seconds again to reset.
  4. No activity on the pushbutton for 10seconds exits edit mode and the lamp goes off.
  5. To verify current set value - at any time when not in edit mode, pressing the button for 2 seconds, but not 5, and releasing it, flashes the lamp the same number of times as the current value set.
That's off the top of my head and would require a good bit of logic, but possible. Personally I don't think I would go to that trouble, but it would be interesting to try it.
Think...what would suit the operators best?
G.
MagelisSTO_1.PNG MagelisSTO_2.PNG MagelisSTO_3.PNG MagelisSTO_4.PNG MagelisSTO_5.PNG
Thanks again
Hello again people
I have taken Geospark's recommendations on board and after
much research have just ordered Magelis St0511 mini HMI
downloaded trial version of Vijeo Designer.
This is my first Hmi project so fingers crossed ,
Have been playing with Vijeo and managed to design ,validate and build
project now just waiting for Hmi to arrive .
Download and simulate
then deal with comms .
Thanks again everyone,
Billmac
Billmac,
Just so you know, Vijeo Designer Limited Edition is not a Demo. You have a full version software product. There are no restrictions on what you can with it for the STO and STU HMI. Only when you go up to the mid to higher range Magelis HMI do you need to purchase a software licence before you can download a project to them. Other than that, all features are available to you.
Radionics also stock the licenced software, currently at £333.77. If you are using a lot of the HMI requiring the licence, it's a relatively small one off payment.
You don't necessarily need the USB programming cable, but the cable is less hassle when you are playing around with small mods in the workshop and regularly downloading your updated project. It connects your PC to the mini-USB port. You can also transfer projects to a USB flash drive and use the standard USB port to load your projects when the HMI is at the machine, saving you bringing the laptop there.
The helps files are pretty good and you should get a training video with the software, but if you need to know how to do anything in Vijeo, ask away, and if I can, I'll gladly guide you.
I can also assist you with the comms. You have a choice of DF1 or DH-485 to the ML1100.
I've written a sort of How To here before to a ML1400:
http://www.plctalk.net/qanda/showthread.php?t=75437
If you have any comms questions ask away.
G.
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,596
Hardware: Micrologix 1100 & 1762-IF4 Analog Input Module Problem: I have one 4-20mA transmitter hooked up to I1:0, I am monitoring the current...
3,413
Hello. I am unable to find information regarding the input mapping for the embedded inputs for the Micrologix 1100. as far as I can tell, inputs...
1,621
Micrologix L16BWA It has two built in analog input ports. How do I change the input type and range? current/voltage, 0-5v, 0-10v, 4-20ma, etc...
3,917
I am attempting to make a cleaner menu of the LCD display and I was wondering if there were raw input bits from the Keypad (Up, Down, Left, Right)...
1,191
