ML 1100 & Wavecom Fastrack Supreme 20 - SMS PROBLEM
sbhussain01
Feb 2010
Dubai
Hi there Guys,
My first post on this Forum !
I have a Set-up for sending SMS from PLC to Modem -
MICROLOGIX 1100 PLC - WAVECOM FASTRACK SUPREME 20 MODEM
I am using AWT block,the source string has the characters
AT+CMGS="+XXXXXXXXXXXX" ^M THIS IS A TEST SMS ^Z
So whenever the rung goes false-true this string is sent to the Channel 0 of the PLC and to the modem -
The first time the rung goes false-true NO SMS is received....
The Second time the rung goes false-true i get an SMS and the text appears like ....
AT+CMGS="+XXXXXXXXXXXX" THIS IS A TEST SMS
The same program works fine with older version of Wavecom Fastrack (Not Supreme) without any difficulty.
I have been trying to sort out the problem since a long time now but in vain.
Please help....thanks in advance.
This is just a personal thing, but i always tend to send 2 seperate AWT commands separated by a short timer (say) 2 secs. Send the mobile number first...short delay...then send the message body.
Works every time for me (although i have never used the modem vendor you refer to).
Hope this helps.
Regards,
Rob
I didnt find any literature explaining the ASCII DATA format to be sent to the Modem but actually that helped......
Thank a lot for the Help Rob.
But the PLC can't read any data from the new Modems....the previous model of Modem used to read the responses given by the modem without any problem.
Regards,
Syed
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
141
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
545
I'm retrofitting equipment, but I didn't want to change the electrical characteristics of the panel. In this equipment I have a dedicated...
73
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
198
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,198
