ML 1500/1100 MSG help
kbradray
Jan 2006
Columbia
175
I am trying to message between a ML1500 and a ML1100. They are on an Ethernet network in the following configuration.
ML1500 (DF1)à NET ENI (192.168.1.150) à ML1100 (192.168.1.151)
Could someone share a MSG configuration from one or the other? I have a MSG Read from a SLC 5/05 to a similar ML1500 by using the Multihop tab on the setup screen, but I do not see the same tab on either the 1500 or 1100 MSG instruction setup screen.
Thanks in advance for any assistance.
You have to use the -ENI configuration tool to set the -ENI IP address and in Message Routing put the IP address of MX1100 in destination 45. (this address uses multihop)
Save this settings in -ENI and start to write a MSG in MX1500 as 500Cpu Read / 500Cpu Write and use as LOCAL address the one you configure in -ENI utility (45)
Other MSG parameters as needed.
Hope this helps....
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
Thanks F L
I have configured the NET ENI for node 45 to the IP address of the ML1100.
I have not tried the message instruction in the 1500 yet. Does it have to be in the 1500 because of the ENI or can it be done on either side?
Thanks again
With the suggested configuration, MSGs must be prepared in MX1500.
You may also realize a MSG from MX1100, but settings are different and also MSG instruction in MX1100 has a new data type for routing via ethernet... :sick:
Hi Guys, New to this forum. I am in selection phase for a Data-logging project. Requirement is given below. Data should be stored in battery...
3,958
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
104
129
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
361
