ML 1500 program lost
Adam303
Aug 2009
Chicago
587
Hi guys we had a problem with our ML 1500 (LRP). The ML is connected to a PV 600 standard thru DH 485 channel 1. The PV gave a fault “no nodes found on network” I connected to the ML and the program was gone. The ML did not fault out but instead had the attached program I was able to download and post. The ML also has a memory module That I would think the PLC should boot from if there is a fault attached is the program and the screen shot of the processor status Mem Module. Any help as how this could have happen and why the PLC did not fault out, as well as where did the program come from? Thank You
  • ML1510.zip
See pdf below for what the memory module status bits mean.
As far as losing it's program, check grounding and make sure all
inductive loads have surge protection.
Thanks mickey. any idea on why the processor would not fault out? insted it had the attached program stored in the processor?
The file you posted had no program at all. Other then the channel configuration it is a defaulted processor.
Just a guess because I've never used a memory module in a ML1500, but is it possible the program was never copied to the memory module and when the processor had an error the blank program got copied from the memory module?
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
For a project in TIA 17 with S7-1500 plc and WinCC Advanced I need to be able to know the acknowledgement status of a program alarm in the PLC...
544
Hello, I´m complete beginner so sorry if my question is stupid. I want to upload the program from the PLC to my computer. I have S7-1500 in my...
4,515
I acquired an Allen Bradley 1500. I built a crappy switch board thing (i think if it looked better it would be called a "trainer") to send inputs...
1,741
had an issue tonight, program was being lost in a micrologix 1500. reloaded it several times, every time it went out it was running, never while...
4,544
