Ml1000
A ML1000 can only be DF1 Full Duplex or DF1 Half Duplex Slave.
The DF1 Polling Master Driver in RSLinx should work. You will have to set the station address something different then the ML1000 and the baud rate default for the ML1000
is 9600. You will also have to include the ML1000 in the polling list. and the com port your PC is using.
Post the file you downloaded ( zip it first) and someone can check how the port on the ML1000 is configured.
The polling master driver worked, must have been a problem with the ML1000, I left the polling master driver on and had to do something else. I came back and the ML1000 was found, kind of crazy, I got online and everything was super slow, then I saved the program, went offline, cycled power and went back online and everything was fine. Thank you very much for all of your input!!!!
Hi all, after much aggravation trying to get my SLC5/04 to talk half duplex to RSlogix so l then would be able to communicate with both RSlogix...
2,245
I have a customer with an existing ML1000 that we installed quite a few years ago. It's function was rather limited but did what we wanted. New...
2,683
I feel really, really dumb asking this, but I shall. I am using a Micrologix 1000 to toggle two outputs. I am using a timer to time and it...
1,497
I have set up two 1761-net-eni modules and have them working on our network. One module will communicate with the ML1000. The other gives 2-3...
1,769
I have a customer that has a ML 1000 we installed years ago. It is limited to the function of Stopping a series of motors when bin limits go HI...
1,709
