Reset counter when power is reapplied (ML1000)
Radlee
Nov 2015
Dublin
I feel really, really dumb asking this, but I shall. I am using a Micrologix 1000 to toggle two outputs. I am using a timer to time and it drives a counter. My goal, which I've accomplished, is to toggle two outputs and have them get faster and faster over a 10 second period. After the 10 seconds, both outputs stay on. So it's BLINK ......... BLINK, BLINK.....BLINK, BLINK....BLINK, faster and faster until both come on. The problem I have is a dumb one. I need the counter to RESET anytime power is shut off and reapplied. Regardless of the previous state of the timer or counter. I should know this, but I'm having a DUH moment. HELP?
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
111
Hi y'all Just a quick question for using Rslogix 5000 I'm using a counter up bit with an analog signal (0-10V). When 10V is measured, counter...
238
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,793
Hello I have a AB Compact logic 1769-L32E controller. I'm wanting to reset a counter at the end of each month. Since the months have different...
34
9,550
Working on delaying running a program in Fanuc robots by a distance (encoder counter). I can delay the program using the encoder counter but there...
1,248
