VJTX Member V Join Date Oct 2007 Location TEXAS Posts 126 May 14, 2010 #1 Does the 1100 have a real time clock or do you have to purchase something else?
Clay B. Lifetime Supporting Member C Join Date Jun 2005 Location Concord,NC Posts 1,304 May 14, 2010 #2 Real time clock is built in
Clay B. Lifetime Supporting Member C Join Date Jun 2005 Location Concord,NC Posts 1,304 May 14, 2010 #4 Go to your help menu on RS Logix 500 and type in RTU in the search window and all the details you are looking for is there. The RTU data is in your function files.
glenncovington Lifetime Supporting Member Join Date Apr 2002 Location Gloucester, VA Posts 303 May 14, 2010 #6 Under the controller properties go to the function files folder. In there is the RTC tab so you can setup the clock. In your program you can refer to the clock with the RTC:0.YR,RTC:0.HR,RTC:0.MIN, etc.
