tlona
I have a AB ML1100 that I am using to collect data from a device sending data over Modbus TCP/IP. From what I understand I will have to use the serial channel on the ML1100 not the ethernet port. I assume then I will need something to convert the modbus TCP/IP back to serial. Does anyone know if the n1761-net-eni will do this or is there some other third party device I will need.
thank-you
thank-you
